Air pressure in the Titans 589 M/T
Old Jul 26, 2002 | 07:17 PM
jlpier01's Avatar
To measure pressure, Do you ever find two gauges that read the same? I have used the little plastic ones that come with quads and they are usually a pound off from each other.
I even bought two of the fancy dial-type gauges and they were not within two pounds of each other. I know this may sound like hair-splitting, but a pound of error at 5 pounds is a 20% error.
Old Jul 28, 2002 | 04:01 AM
Elrancho's Avatar
It seems like if one could get a gauge like is equiped for blood pressure cuff's that might be about the right range and quality for getting accurate readings.
Old Jul 28, 2002 | 09:56 AM
jlpier01's Avatar
I was actually thinking about McMaster Carr, or Grainger as well. Anything would work as long as it is calibrated.
Old Jul 28, 2002 | 11:36 AM
Haynes1111's Avatar
I tried 3 lbs front and 4 lbs rear, ride was great but was concerned with high speeds on tight trails. Last PM rode with 4.5 lbs all around and it seemed great for all riding styles.
Old Jul 28, 2002 | 09:55 PM
  #15
tommm's Avatar
4x4 rancher if you leave email i will mail you some pics
Old Jul 29, 2002 | 01:11 AM
  #16
4x4rancher's Avatar
fugitive56@hotmail.com
Old Jul 29, 2002 | 12:40 PM
  #17
Parker650's Avatar
Rode 27" 589 M/T's on a 02 Grizz this weekend. Those tires may be good for rock crawling and mud, but high speed trail riding NOT AT ALL. Couldn't corner at all and when the trail turned left slightly, the quad just kept going straight at 50 mph, I tried everything and couldn't get that thing to turn. The quad and I were both ok after getting back on the trail, but it was scary as hell and I switched back to my 650. Never again 589 M/T's. Funny, the 589 M/S are great, my friend has em on his 650. I can't believe they'd be that different. Maybe it was the quad/tire combination.
Old Jul 29, 2002 | 01:00 PM
  #18
Haynes1111's Avatar
I had to set my front end toe to zero ( as per nyroc instuctions) to stop that from happening. My Titans 589 MT appears fine now at high speeds.
Old Jul 29, 2002 | 01:38 PM
  #19
trx450's Avatar
Parker--- I would agree about the toe setting being off, esp. if the problem was only Left turns! My 4-Man was very stable with the 589 M/T's. Haven't tried them on the P-650. I run Spiders frt., Shur-Trax rear in 26".
bmxatv10
Oct 14, 2022 06:23 PM
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
2many2ride
Sep 27, 2015 04:35 AM
MPDano
1) Engine problems..
Sep 20, 2015 09:48 PM
Hw00d
Sep 10, 2015 08:53 AM
