Why won't my Mojave Start??
Old Jul 22, 2002 | 11:08 PM
MojaveRider250's Avatar
Yea i think unless it would mix with the other gas!!
Old Jul 22, 2002 | 11:12 PM
TeamGrnMojave269's Avatar
Thanks, MojaveRider250 I'm going to give that a shot tomorrow when i get home from work. Hopefully that will work...Thanks again for your help I worry about my baby when she wont run!!
Old Jul 22, 2002 | 11:42 PM
BigChris's Avatar
Yeah that sounds about right to me....makes sense it oviously wont run if the gas is mixed with something (water) So drain it and let it dry out for a while then hopefully it'll start for you. If it doesnt start for you right away after you did all the stuff ^ try spraying some starting fluid on it and kick it for a while...good luck
Old Jul 22, 2002 | 11:45 PM
mojaveman1's Avatar
if you try that and it dont work its the carb now
it sounds to me like one of you jets it clogged with a drop of water they just like to stick there
it idles when it is not pulling fuel from that jet then when you hit the gas it starts to suck from that jet and cant get any fuel
maybe im wrong but its worth a shot
Old Jul 23, 2002 | 11:04 PM
  #15
The Mojave is ALIVE!!!!!! Thanks everybody, as it turned out some how the carburetor had completly come alose from the motor there for keep the motor from getting any gas I guess. But I also drained all the gas and filled it with some Fresh 93 octane!!
Old Jul 23, 2002 | 11:11 PM
  #16
minnesotaMOJAVE's Avatar
ur spark plug is bad, ur compression is terrible if it cant comp start,if u dont have the air filter cover on u hav to much water in the engine/ect and u might hav to suck it out with a straw like my uncle did on his kodiak after it fell in lake superior.
1000gade
May 27, 2015 12:37 PM
2punksdad
May 23, 2000 01:46 AM
Reconrider
Aug 30, 1999 02:17 PM
dunc_n
Aug 26, 1999 09:32 PM
RidE
Aug 6, 1999 02:34 PM
