650 carb synchronization
Old Jul 23, 2002 | 11:05 PM
Haynes1111's Avatar
Can you visually see if you carbs are not in synch? Can you put them in synch without a machine? I read somewhere if you add a aftermarket pipe you will need to have your carbs synchronized. Is this true? Hopefully I will install my dynojet kit this weekend and I need to know if I have to worry about the carbs. Any help greatly appreciated. I plan to jet at 132 front carb and 136 jet rear carb with the needles set on the 4th groove. I live below 3000 ft above sea level. I have never been much of a mechanic but feel I can handle this job as long as I don't strip the screws as I have been reading about.
Old Jul 23, 2002 | 11:29 PM
nyroc's Avatar
Nope, you can't see if they are in sync (hear maybe, if your ears are really well tuned). I used to have an inexpensive carb sync tool, but can't find it. It was just a floating ball type that sits on the stack and the ball rose higher with more flow. I adjusted the balance screws until the one barrel was close to the reading on the other. I may order one. I hate to, but I don't like other people servicing my stuff.
If our 650's were even firing, they would only need one carb. But even firing would make them vibrate. Can't have everything.
Old Jul 24, 2002 | 10:51 AM
Surveyor's Avatar
Roc,
I have a few bikes in the garage (v twin & v four, plus the prarie)..so therefore I use a set of carb sticks on a regular basis..more often than most folks would use them..so take the info for what it's worth..(free)
I startrd out with a set of motion pro economy sticks from dennis kirk (about 40 bux) then after about 8-9 months or so the cover that seals the mercury got loose & I had to get more mercury..(you know that you can't get it locally, can't be shipped by air and is about 20 bux for a refill, right?) so after going through that, about 6 months later one of the tubes is cracked..so instead of having motion pro send me a new one, I ended up getting this one
carbtune it is about 80 bux (for the 4 cyl model) the 2 cyl model is cheaper (about 64 bux), comes in about a week, a lot more sturdy, & has no mercury.. I should have done it the first time..
I haven't tried it yet, but it is coming..
time for some maintenance on the bikes & quad..so I'll let you know how it works out..
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
