engine oil
what brand of oil should i get for my p650. the oil change is coming up soon and i usually run penzoil. but i heard to stay away from car oil. so i was wondering what brand and what viscosity (10w-30 or whatever). thanks alot. i will appreciate any response.
thanks alot. does i know 20w-50 oil is thicker than the other numbers, but does it still perform good in winter because it is so thick or should i get something else for winter. or should i use mobil 1 v-twin 20w-50 oil all year round? thanks alot for the response!
are synthetic oils better than normal oils or what? i havent ever used synthetic. is it better? what are the differences? why do they make synthetic oil. is sythetic better than normal oil in the kawa prairie 650. thanks. i know im asking alot.
Packardbell,
I run synthetic in my 650 because if you happen to put it under water it will come clean easier. I have been using Castrol Syntech but have recently changed to Penzzoil 5W30. The lighter weight helps to cool the engine better. I also use High Lifter additive in my oil. 4 oz. per change. It will make the engine run cooler in the summer. Good luck!!!!!!!!
i think im going to run amsoil in my atv because synthetics make ur engine last longer. is it ok to run amsoil synthetic oil in my atv. and where can i get an oil filter for my p650 that WILL WORK. thanx alot.
There are so many filters to choose from. STP SMO-017 is what I get.
See this motorcycle filter page. Print and take it to the parts store. These will pretty much all fit the 650. They don't all fit all quads though, length problems or thread depth problems (the 660 has thread depth issues with some filters).
You might be better off using mobil MX4T than V-twin, since the MX4T is formulated for water cooled, and the V-Twin is formulated for air cooled. Oil doesn't care about engine configuration (V, inline etc). Oil does care about other stuff like temperature, and clearances. Synth pumps better in the cold anyway so even 20w50 V-Twin surely is better than using 10w40 Dino oil in the winter.
Amsoil is great, I just can't get it as conveniently.
