Prairie 650 Jetting Question
Old Sep 9, 2002 | 10:45 PM
EXT's Avatar
EXT
HMMMMMMM
That you Scott???
Nova??
Old Sep 10, 2002 | 10:39 AM
NovaKaw650's Avatar
<< HMMMMMMM
That you Scott???
Nova??
Sur is. Scott W., that is. Who are you ,Ext?
Old Sep 10, 2002 | 04:32 PM
EXT's Avatar
EXT
Graham Campbell here
We should get together for a run sometime now that fall is coming.
I'd like to compare notes on your mod 's on the bike as well.
Old Sep 10, 2002 | 05:30 PM
NovaKaw650's Avatar
Graham, check your PM's.
Old Feb 26, 2021 | 06:22 PM
  #15
Tjanddj Clifford's Avatar
Default Clip on the needle
Originally Posted by kawlaris
I just finished rejetting my 650 again. I am using DiamondG snorkle, K&amp;N filter, &amp; BigGun exhaust. I went with the 4th pos on the needles and 132 f/136r. I also encountered a &quot;blubber&quot; at probably around 2/3 throttle. It would continue to backfire and miss as long as I held that speed. If I continued excelerating it would be fine. I just installed 130f/134r and now it runs perfect throughout the power band. After the engine warms up I have problems keeping it idleing and have had to turn the idle up. My fuel mixtured is turned 31/2 turns out which helped it to start easier. Good luck on finding correct jets!
What year p650 has a clip in the needle I have a 2002 and it only has shims
mpap
Aug 31, 2004 08:29 AM
PipeIt660
Sep 7, 2003 12:33 PM
joeskvf650
Jun 17, 2003 09:24 PM
Bosox07
Mar 23, 2003 08:20 PM
Haynes1111
Jan 31, 2003 02:54 PM
