Prarie 650 Squeal - Front End
Old Oct 29, 2002 | 11:31 AM
urals47's Avatar
Default Prarie 650 Squeal - Front End
I have a Prarie 650 that has about 100 hrs. It just recently developed an intermittent short squeal eminating from the front end. IT sounds like it is directly coming from just behind the steering column. I removed the drive belt housing and it was bone dry. I tested the belt by applying brakes when throttling up and it does spin slowly around the shafts. Is this normal and could this be causing the noise? It doesn't seem to be badly worn but I didn'tthink it should spin with brakes applied. The sound happens when first throttling up - forward or reverse and is intermittent. THe breather housing is housed directly above the belt housing and comes up through the plastic cowling and I was wondering if this was where I was hearing the noise. Also, my shifter sometimes is hard to pop-into gear. This is also intermittent. Any advice grealy appreciated before I take it to the local experts.
Old Oct 29, 2002 | 02:05 PM
YoeSeaOh's Avatar
the shifter can be adjusted but the condition is pretty much normal. If the squeal is the belt deflection you can remove a shim from the driven pulley to tighten it up.
Old Oct 29, 2002 | 02:22 PM
urals47's Avatar
Thanks much,
Found some info regarding belts. Dealer has one for $80. How hard is it to remove shim and tighten current belt. Don't have repair manual for 650.
Old Oct 30, 2002 | 06:08 AM
monteSS's Avatar
It is real easy NYROC's site give good instructions on how to do it. Look for a post by him and then go into his site from there. IT will be under MY tech tips.
Old Oct 30, 2002 | 07:31 AM
trx450's Avatar
nyrocs 650 site is an excellent source of data and info. I would strongly suggest that you spend the $30.00, or so, on the factory service manual.
Old Oct 30, 2002 | 09:58 PM
newfieboy58's Avatar
Weekend Warrior: I have the same problem I get a squeal when I start off
just for a sec or two when I put it in foward or reverse. I have the 2003 360 prairie. If you find out how to correct this problem let me know. I still have 3 months warranty on the bike yet maybe warranty will cover it[img]i/expressions/face-icon-small-smile.gif[/img][img]i/expressions/face-icon-small-wink.gif[/img]
Old Oct 31, 2002 | 07:19 AM
trx450's Avatar
newfieboy-- YOUR problem is most likely belt squeal. My P-650 does this, I adjust the belt, and it goes away. It is a little loose.
Old Oct 31, 2002 | 10:42 AM
urals47's Avatar
newfieboy>>> Two choices. If it's under warranty take it to dealer and get a new belt. Or- go to NYROC's Web Page and under techical help section you will find belt replacement information.
Old Oct 31, 2002 | 05:10 PM
[img]i/expressions/face-icon-small-smile.gif[/img]Thanks urals47 and pro rider for the response. My bike has 3 months warranty on it yet so if it is the belt it is covered under warranty.The reason I ask cause I have to bring it 4 hours from here but if not I will try and fix it myself with some instructions from this forum.[img]i/expressions/face-icon-small-happy.gif[/img]
Thanks again
Old Nov 1, 2002 | 08:18 AM
trx450's Avatar
newfie58-- I'd call or radio ahead to make certain that the dealer will cover the job under warranty, and that they have the parts to do the belt replacement and/or adjustment! 8 hours driving, only to find NO parts would ruin MY day!
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Aug 6, 2015 10:46 AM
toonces
Aug 5, 2015 05:55 PM
carolinabomb
Jul 26, 2015 08:40 AM
tporath
Jul 11, 2015 12:31 PM
