650 wiring ?
Old Nov 3, 2002 | 09:42 PM
Oshawa's Avatar
Default 650 wiring ?
I am wiring a back-up light to my 650 but I need to know which wire is for the reverse indicator light.
Thanks.
R.
Old Nov 4, 2002 | 07:16 AM
nyroc's Avatar
The hot wire for the reverse light is always hot with the key on, so you can't use that.
The light comes on when the revese switch grounds the negative pole of the revese light. That wire is red with a white stripe (R/W it says in repair manual). I do not know if that switch can take as much current as you need for the light, so you may want to think about using a small relay that is activated by that revese switch to give you the power to run big backup lights.
Old Nov 4, 2002 | 07:50 AM
trx450's Avatar
I agree with nyroc. You probably will need to use a relay. There should be room to install one with the rest of 'em under the seat.
Old Nov 4, 2002 | 08:16 AM
monteSS's Avatar
Unless you would use the clear LED lights. They draw very little current. My Motor cycle I can't use them because they draw so little current my taillamp "burned out indecator" stays on all the timeand doesn't even see it in there.
Old Nov 4, 2002 | 08:17 AM
Oshawa's Avatar
Thanks for the info. Yes I have set this up using a relay. So are you saying that the red/white wire is the grounding wire or the permanently hot wire?
R.
Old Nov 4, 2002 | 02:28 PM
nyroc's Avatar
red/white is grounding. I forgot what the hot one's color is. I am at work (crummy job) and can't look anything up.
Old Nov 4, 2002 | 11:11 PM
Oshawa's Avatar
I put the relay under the seat right below the tool box. I spliced into the red/white under the seat in works great. Thanks for telling me that it is a ground switch, saved me alot of cursing. Who knows I could of had a fit and knocked over my beer.
Cost of light- $15
Relay and connectors- $8
Working on my quad and having a beer- PRICELESS!!!
toonces
Sep 5, 2015 01:14 PM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
quickwhips
Sep 2, 2015 06:53 AM
frostphase
Aug 19, 2015 07:11 PM
DeFox500
Jul 26, 2015 06:32 PM
