'Clank' sound while in 4wd Low
Old Dec 25, 2002 | 02:44 PM
mastrblastr's Avatar
Default 'Clank' sound while in 4wd Low
Raynist, I adjusted my linkage this morning after all the gift opening. Needed to get out of the house anyway!! PROBLEM SOLVED!!!!! I wound up basically "shortening" the linkage by about 1/16 of an inch or so. That's all it took. I took my quad across the street where they have a small hill and gassed er hard all the way to the top. No clank at all. Hope this is your problem as well, as it is a very easy fix.
Old Dec 25, 2002 | 11:20 PM
nyroc's Avatar
Next time I take the middle plastic off I'm going to change the range adjustment on the shifter just a little. My shifting works great, but I think it would be the most correct if the range was adjusted longer. That's the adjustment on the shift selector itself, in case someone doesn't know. Most people haven't needed to do it..
exmotocrosser
Sep 13, 2019 06:12 AM
flyin-lowe
Dec 1, 2017 03:18 AM
mrtidy
Feb 3, 2016 05:00 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
Polaris Side by Sides
Sep 15, 2015 03:33 AM
