weak lakota
Old Jan 12, 2003 | 12:15 PM
garyvegas's Avatar
Default weak lakota
Started up the Lakota ('98) yesterday and it started fine but it seemed to take a long time to warm up, had to leave the choke on way longer than usual. My son wanted to race the Polaris Trailblazer ('01) against the Lakota. I told him it wouldn't even be a contest. The Lakota has a Supertrapp exhaust and a K&N filter, the Trailblazer is stock. Well we took off and he kicked my butt! The Lakota just seemed to have no power, sort of bogging down thru all the gears. Anybody got any ideas? This thing ran like a raped ape only a few weeks ago.
Old Jan 12, 2003 | 11:02 PM
TheFatGuy's Avatar
Default weak lakota
something in gas lines mabye there kinked. fowling plug? those might be the prob.
Old Jan 13, 2003 | 07:16 AM
mojavekid13's Avatar
Default weak lakota
Ahh it kinda sounds like u are have carb problems! It is somthign to do with your gas! Check all your lins that come off your petcock all teh way to your carb! one tiem i had a little pin hole in one and it did the same thing! If not then check your plug!
Old Jan 18, 2003 | 09:01 AM
mudnmyeye's Avatar
Default weak lakota
Sounds like the carb. If the previous postings dont fix it, you might want to remove the top of the carb and check the rubber diaphragm for tears/ holes. If it's ok, carefully re-assemble, w/o pinching or tearing the rubber. (~$100 to replace). If you havent been in the carb prior to this, it probably ok.
Check your throttle stop at the handle bar. Your son probably pulled a fast one on you!
ultangler
Nov 30, 2024 01:35 AM
ltrmc02
Aug 22, 2021 02:34 PM
MATT BOOTH
Technical and How-To Articles
Sep 22, 2015 08:35 PM
Jaymc
Sep 11, 2015 07:45 AM
mattcraig1
12
Aug 27, 2015 12:23 PM
