P 650 need advice
Old Feb 5, 2003 | 03:37 PM
couga21's Avatar
Default P 650 need advice
Alright gang here it is;
I just installed hmf exhaust, k&n airfilter, snorkel, and jets 145r & 142 f I think I have every thing dialed in right because got more power and no pops or misses when I'm on the throttle. But on top end I lost a couple of mph. This is really not to big a deal but I wondered has this happened to anybody else. Also I noticed that when I start to give it throttle my belt starts to squeak. I just wanted to make sure does this mean my belt is loose and do i need to take out a spacer? Would a loose belt be the cause of the lost mph? Any feedback would be extemely helpful
Thanks
Old Feb 5, 2003 | 04:29 PM
JAMMER's Avatar
Did the same HMF,K&N,Snorkle,145,142, 1,1" hole in airbox.10% more power. Do the Black EPI spring With no shims you should be good to go.Dont forget the Progressive springs out front.
Old Feb 5, 2003 | 04:50 PM
SHOTGUN's Avatar
YES, you will lose speed from a worn belt. if it is squealing adjust it, go with the black spring, if you don't have it, that will help with wear. You also may be over revving..
ultangler
Nov 30, 2024 01:35 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
kodiacrunner
Oct 4, 2015 11:52 AM
wrencher82
Sep 28, 2015 10:02 PM
