Mairer Handgaurd Installation
Old Feb 6, 2003 | 12:59 PM
DirtyDawg's Avatar
Default Mairer Handgaurd Installation
Just curious how anyone elses' install went.
Seems that the front handlebar cover doesn't fit correctly after the install.
I can rotate the gaurds and the brake levers down and it fits okay but at that point you don't really get much protection in the knuckle area.
I trimed up the plactic in a few places with a dremel tool and it fits okay again. The tight spot is on the right side and the brake cable.
Has anyone bought a handlebar bag after they put the handgaurds on?
Old Feb 6, 2003 | 01:54 PM
FastEd's Avatar
DirtyDawg,
I put the Moose hand guards on a few months back and was also displeased with the fit of the right side guard. With the limited way that the right /front brake lever can be adjusted, Moose and Maier should have made their products to fit better. The right hand side guard is rotated down so far that it does not look or perform as well as it could. In addition, the Moose guards can not take any shock in really cold weather. Both of mine have broken and had to be "zip tie" repaired.
ED
Old Feb 6, 2003 | 05:35 PM
NovaKaw650's Avatar
I got my Maiers to fit good, but it was like pulling teeth. My next set of handguards will supported by the ends of the bars too. Part of the Maier installation uses zip-ties and they (the zip-ties) break every time I hit a small sapling or branch.
ReconBayou
Oct 31, 2022 05:37 PM
2many2ride
Sep 27, 2015 04:35 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
