mojave valves
Old Feb 28, 2003 | 01:15 PM
ace1's Avatar
Default mojave valves
it's time to adjust the valves and could use a little help .has anyone out there done this ?what am i instore for? and any suggestions on new a pipe .
Old Feb 28, 2003 | 03:47 PM
AlkyBurninX's Avatar
Are they extremely tight? They might have started pulling through the head like Mojaves are famous for.
Old Mar 3, 2003 | 02:10 AM
ace1's Avatar
I've never adjusted the valves on this bike so I would not know if they have pulled through the head and the bike does'nt sound so good right now I burned through a tank faster than my wifes snail blazer . any tell tail sign's to look for ? what's the time line on this job ? and the big question ,cost of doing it yourself as aposed to getting it down at the shop !
Old Mar 3, 2003 | 07:38 PM
picklejuice52525252's Avatar
hopefully by adjusting the valves , like the distanse between the top of the spring and that metal peics that the camshaft presses if this is so it is really easy to do, just take all the plastic and the fuel tank off, then undo the 4 tob bolts on the head and the 2 on the left side (looking at it from behind) then carefully take it off you dont want to screw up the gasket (which is pretty thick and durable, more rubberish)
then take a feeler gauge set for .08 i tihnk it is and slid it between the spring and that metal peice take a socket and undo the top bolt on top of the metal peice on top of the springs after that stick the feeler gauge in and move it back in forth while adjusting the gap with a flathead screwdriver so that there is a LITTLE bit of pressure on it then hold in that place while you take screw the locknut back down on it so its tight then pull the flathead out and put a wrench on it and replace the flathead back on top of where you had it before, now while keeping the thing your holding with the flathead still while you tighten the bold with your other hand (has the wrench) and then tighten it as good as you can the put and appropriate socket on a tourqe wrench and tighten it to specifications (i tihnk it is like 25 or 30 go for 30) now double check the gap to see if it is still good now repeat all this for the other 4 remember to remove the cover out the LEFT side of the bike (sorta wedge it out its a tight fit) that should do it, clymer manual will tell you also how to do it , hope this helps
Old Mar 6, 2003 | 03:06 AM
ace1's Avatar
bougth the book pulled the skin ,valve cover adjusted the valves .008 ,fired right up the first kick but Istill am getting valve noise .put a screw driver to each valve area and the intake sound great one out of two exhaust valves sound loud the side w/ the compression release unit on it not to mention the cam chain tensioner does'nt seem to be right , I put a screw driver and pressed it in a bit ,the majority of the noise went away ,Iam expecting a surtin amount of noise but .............. you got me ??? let me know !
i
Old Mar 6, 2003 | 09:30 AM
mojavekid13's Avatar
haah I have had my mojave for about 3 years nwo and have never adujusted tehvalves!
i thnik iam gonna get that done soon! hahah
What is a sign of them pulling through the head?
Old Mar 11, 2003 | 02:52 AM
ace1's Avatar
you know i don't know yet did find out that the chain tentioner was bad and the cam chain was strectched intake valves are normal . one out of two exhaust valves are questionable , but i am waiting for my new chain and cam chain tentioner to see if the niose is going to go away i get the parts this week and if this don't fix it then i'll pull the top end and tell you what to look for , but i did here that the valves are super soft and being off a small amount can screw them up.......
Old Mar 11, 2003 | 08:08 AM
Well how often are you sapose to chech them?
and is it a job you can do your self! and also after you reset them is there any kinda break in time or any thing!?
Old Mar 15, 2003 | 01:30 AM
ace1's Avatar
no break in time, but they recommeend every 30days or i think about the time when you change the oil and clean the air filter. if you don't have the book buy it it is the best 30.00 i've spent so far for it
Scooter's Shop
23
Oct 22, 2015 07:04 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
