VForce Engine?
Old Mar 7, 2003 | 05:00 PM
RebelDS's Avatar
Default VForce Engine?
I see where the 650 is rated around 42 horsepower, but what is the 700 rated? I got to thinking about what would happen if I blew my 650 motor. Would a VForce engine fit in a Prairie? I don't want to blow my engine, but just wondering what it would be like to put a VForce engine in a Prairie. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Mar 7, 2003 | 09:41 PM
SHOTGUN's Avatar
Same motor, different bore and stroke.
50cc would help, but not much. Get a CDI box, then a big bore kit. Diamond G and Mickey Dunlap
Old Mar 7, 2003 | 09:46 PM
mudboger's Avatar
No you cant put a v-force into the prairie.But you can put the crank and cams and bore it 2mm and have the same engine.Combine the crank with the F.S.T 750 kit and get a 785 then put on the cdi and a good exhaust and hold on.The v-force is rated at 50hp and 43lbs the prairie is 42hp and 34lb.have fun...later
Old Mar 7, 2003 | 10:16 PM
DustinMinnesota's Avatar
First consideration is the V-force does not have the internals for 4 Wheel Drive..... Stick to ya block and bore bore bore
Old Mar 7, 2003 | 11:00 PM
pleasure4qt's Avatar
Can't wait to see the new V-Force on the dyno and see how effectively the shaft drive puts the power to the rear wheels on the beast. Hp and Torque #s please.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Cummins Driver
Sep 11, 2019 01:22 PM
austinwhitton
Aug 11, 2015 06:21 PM
Jul 30, 2015 09:39 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
