Running rich
Old Mar 14, 2003 | 10:13 PM
gtchief's Avatar
Default Running rich
I pulled my plugs the other day on my P650 and the tips were black, so I assume I am currently running rich. I finally ordered a Twin-air filter from my dealer and hope to have it tomorrow maybe. Since I am running stock right now do you guys think the new filter will straighten it out for me? If not, how hard is it to adjust my carbs and how do I go about doing it? Thanks in advance.
Old Mar 14, 2003 | 10:19 PM
jefffoxsr's Avatar
Don't assume you're running rich. How does the quad run at various throttle points? Any symptoms?
Old Mar 14, 2003 | 10:51 PM
gtchief's Avatar
The quad seems to be running fine throughout the power band. I have a slight hesitation from dead stop also, but I thought that was normal.
Old Mar 14, 2003 | 11:28 PM
jefffoxsr's Avatar
Was the base of the plugs black too? Any oil? Was there a difference between the plugs? Have you checked or adjusted the pilot jets yet?
Old Mar 14, 2003 | 11:54 PM
gtchief's Avatar
When I said the tips I meant the bottom tip. I didnt notice any oil or a difference in the 2 plugs. I havent checked or adjusted anything with the jets. Is it possible to do so without any tools if I need to?
Old Mar 15, 2003 | 09:04 AM
jefffoxsr's Avatar
If the black is not really sooty or oily, and based on your drivability report, I would say you're in good shape. You should verify the pilot screw setting for the hell of it. They should be at 2 1/4 turns out per spec. It's still cold in Penn, so maybe 21/2 turns out until it gets warmer. That will take care of the slight hesitation, as the "tip-in" a/f is a bit lean now. Do a search in the kawi forum for my posts on the procedure.
hugemoth
Jul 20, 2020 03:28 AM
Frisky2050
Apr 9, 2020 11:19 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
robj
Jun 15, 2015 08:45 PM
Chawness
Apr 21, 2000 08:14 AM
