650 low range!! Please reply
Old Mar 16, 2003 | 01:09 PM
Scrode's Avatar
Default 650 low range!! Please reply
Hey there guys, on my 650 when i am in low range and you start to speed up it makes a clunking sound toward the front half of the quad. I adjusted my linkage so it would not make those sounds when you slow down in low range and that worked well, but it still make a sound when you get in higher rpms in low range, mostly when all four tires are spinning slightly, for example when you are plowing snow or in a snow bank. It sounds like something is trying to dissengage or somthing, i cant tell if its comming from the front diff or the thansmission. Well i know this might not be the easyest to read and understand but please try to reply. Later dudes
Old Mar 16, 2003 | 01:50 PM
Kawi650's Avatar
Mine is doing that as well, I think it's the linkage by the engine comes loose, not adjustments. Dealer going to get it this week. [img]i/expressions/face-icon-small-wink.gif[/img]
Old Mar 16, 2003 | 02:04 PM
Scrode's Avatar
Hey, thanks for replying, i am glad i aint the only one with this problem, but it sure pisses me off when it does this, is it hard on the machine everytime it does this. And where exactly do you think it is loose. I would liek to take a look at it. Thanx. Bye
Old Mar 16, 2003 | 06:59 PM
Kawi650's Avatar
I hear you... what it's doing is jumping out of gear right to some type of neutral. I'm thinking where the bolts are on the side of the engine. When they tighted the bolts it went away for a while but it came back this past weekend.
Old Mar 16, 2003 | 07:07 PM
macgiver's Avatar
a friend of mine had that problem. it turned out that the low range gears were not meshing propery. it war the ends off of the teeth. it was just out of warrenty and didnt get coverd. i think it was like 2000 bucks to fix it.
Old Mar 16, 2003 | 07:48 PM
Scrode's Avatar
I dont think it would cost that much to fix it, and i don't think it is that serious of a probelm, just a linkage or sumthing. but seya guys later
Old Mar 16, 2003 | 08:18 PM
macgiver's Avatar
thats what my friend thought. just a linkage adjutment. atleast get it checked. its not going to get better with time
Old Mar 16, 2003 | 08:31 PM
Scrode's Avatar
Ya i will, if it is somehting seriosu i will put it up for sale an i will be f*cken mad, there is no reason for that sh*t. But hopfully not, latrer man
ReconBayou
Oct 31, 2022 05:37 PM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
shimanok2
Jan 29, 2016 07:37 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
awer1968
Sep 8, 2015 11:02 AM
