Wiring KLR250 CDI For Mojave
Old Mar 29, 2003 | 03:30 PM
Grizzwald's Avatar
Default Wiring KLR250 CDI For Mojave
I'm planning to add Web racing cams to my Mojave. I recently purchased a used CDI from 1989 KLR250 (ebay $26!). I need to know how to wire this CDI to work on my Mojave. There are two plugs coming out of both units, the color codes seem to match. However, the KLR CDI has one extra red with black stripe wire. I assume it's necessary to swap the plug ends putting the corresponding colors from the KLR box into the Mojave plug. What should I do with the extra wire? Anyone have a wiring diagram?
Old Mar 29, 2003 | 11:17 PM
mojaveaddict's Avatar
Switch the mo plugs to the klr box matching collors. Connect the extra red wire to the other red wire that is the same color so that two red klr wires go to the one mojave plug red wire.
Old Mar 30, 2003 | 12:59 PM
sugarhead's Avatar
MOjave,Wll a KLR box give me seat of the pants feel or decrease reliabilty of my bike if I w sto get 1?
Old Mar 30, 2003 | 07:51 PM
mojavekid13's Avatar
same question! Will it decreas realibilty! Cuz i was thinking about doing thsi also!
Old Mar 31, 2003 | 12:38 PM
you will notice in the seat of pants especially if you have cams and other motor work where you need the quicker advance. Will not improve top speed. will not hurt reliability unless it gives you a detination on accell that you did not have with the stock box. This can happen and if it does you will need higher octane fuel.
Old Mar 31, 2003 | 09:22 PM
Well i also heard that the KLR cams are liek a high proformance cam fo rthe mojave!
i knwo where i can buy a whole KLR with new cams in teh box for 300$ i think i should do it!
Old Apr 1, 2003 | 08:54 PM
sugarhead's Avatar
Mohave,CAN yOU add te ignition box out heavier valve springs ?I have a 2002,las tof the green frames LOL and its got kn filter,dyno jets big gun an thats it for now.I don t wanna float the valves tho just wanna lil bit more snap outta the bike.Also would playing w the fuel screw make any difference.Im hearing more an more bout that lil carb trick in the mags.
Old Apr 1, 2003 | 09:03 PM
the valves will float, be carefull. you guys check out my latest project in a thread here called most modded mojave ever
quickwhips
Sep 2, 2015 06:53 AM
frostphase
Aug 19, 2015 07:11 PM
DeFox500
Jul 26, 2015 06:32 PM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
