air mixture screws
Old Apr 4, 2003 | 09:50 PM
prariedog's Avatar
Default air mixture screws
can anybody tell me how many turns out the air mixture screws are supposed to be on the p 650
Old Apr 4, 2003 | 11:22 PM
650Mountain's Avatar
Ussually between 2.75 and 3, just warm it up real good,with the quad idling turn in each screw (one at a time)until the motor starts to stumble,then back it off 1/2 turn.
Old Apr 5, 2003 | 10:10 AM
jefffoxsr's Avatar
Standard is 2 1/4 turns out. You can go from there depending on the average ambient for your area at the time and change it as needed.
Old Apr 5, 2003 | 05:21 PM
Scotia650's Avatar
We run ours at 2.75r & 2.5f. Elevation below 1000'.
Old Apr 6, 2003 | 05:50 PM
2003650's Avatar
Don't you need a gauge or something like that to make sure the carbs are in sink when you adjust the screws?????????
Old Apr 6, 2003 | 08:11 PM
Scotia650's Avatar
We are referring to the pilot screws which don't effect the balance of the carbs, just the low speed mixture. There are two pilot screws, one on each carb on the right side when sitting on the bike. The carb synchronization screw is between the carbs on the left side.
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Beeline08
Nov 11, 2016 04:00 PM
Oct 10, 2015 10:20 AM
Jackg17
Sep 26, 2015 09:30 PM
