mudlite tire pressure ??
Old Apr 6, 2003 | 05:59 PM
jwkawi's Avatar
Default mudlite tire pressure ??
i have my tires (itp mudlites) at 5lbs rear and 4.5 lbs front. is this ok or should i adjust differently. [img]i/expressions/face-icon-small-happy.gif[/img] thank you in advance for your help everybody.
Old Apr 6, 2003 | 09:32 PM
2003650's Avatar
Sounds pretty good to me. I run mine at 5 psi all the way around.[img]i/expressions/face-icon-small-wink.gif[/img][img]i/expressions/face-icon-small-sad.gif[/img][img]i/expressions/face-icon-small-blush.gif[/img][img]i/expressions/face-icon-small-disgusted.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-mad.gif[/img]
Old Apr 7, 2003 | 03:18 AM
DaveC's Avatar
Sounds good to me also.
I run 6 in the front and 5 in the rear in my 26" mudrunners.
What kind of true tire height are getting with those psi's?
Old Apr 7, 2003 | 05:50 AM
92LT's Avatar
How is the handling with the mudlites at higher speeds? (>35 mph)
Old Apr 7, 2003 | 02:38 PM
jwkawi's Avatar
92lt,
i think the mudlites handle great. ive been up to 50 mph so far and they handle as well as the stock s#$* dunflops. even better, the front end diving on my quad has been severely reduced. i was going to get the progressive suspension but i think i am going to hold off for now.
davec,
ill measure them when i get a chance.
Old Jul 24, 2003 | 10:48 PM
piski's Avatar
my 27" mudlites only measure 26" @4# - 4.5#......they hunt badly on hardpacked trails too......haven't checked toe yet though...anyone else find have this hunting problem ?
Old Jul 24, 2003 | 11:11 PM
jc82's Avatar
yea, my 27 mudlites scare me ....aalll over .I cant go past 40 , I took them off after 100 miles as they took so much ride away, but man they dig, saving them for winter and spring
Old Jul 24, 2003 | 11:13 PM
piski's Avatar
I've been considering the same thing..unless the toe is all screwed up....I'll check it the morning and see.
Old Jul 25, 2003 | 05:45 PM
kybabyn's Avatar
wo okay i run my tires at like 3 4 is it just the mudlites that take more air or something. i run small spidertracs on a mojave and i can just just puch them in abit. i guess it depends what you ride!
Old Jul 25, 2003 | 06:31 PM
Kodiac400's Avatar
Basically the way I do it is play around with the pressure. Example if I find the atv rough I take a bit of air out of the rear. If it stears heavy add air in the front. Only you can tell what is a good pressure. All that I suggest is test drive with lot of different pressure's. I know someone that runs 3 in the rear. Personally I find that it makes body role for nothing.
Good luck
