Mojave Exhaust
#31
JayBR
can u notice a big difference in teh handleing! and also is there a web site where i can check them out!
and do uhave a pic you coudl send me!
seannl69@hotmail.com thansk man! and also .....sorry but do they use the stock spindles? and where did u get the elkas!? thanks
#33
The a-arms bolt right up, they are made specifically for the mojave. They come with upper ball joints and you have to get LT250r lower ball joints. No other modifications are required, but I highly reccomend shocks setup for the wider arms. Handling was definately improved..
#36
Hay guys i really need some help! I have a 93 mojave and the light does not work i thought it was the bulb but i put a new one in and it blue it when i reved it up. It sounded like it was the regulator. i tested it and when i reved it up the volts jumped from 12 at idle to like 40. that should be the regulators job to keep it at twelve volts so i got a new regulator and it still does the same thing. the old reg is actually okay. i taked to some technicians in my town and they said make sure you ground it. i did and still blows bulbs. the olny thing they could think of is that there is a ground somewhere in the circutry. any body have any clue? also im not running any taillight could that have anything to do with it. i tryed hooking up another twelve volt bulb and it just idles at like 9 but still blows. please help?
