Dang jets!!!
Old Apr 12, 2003 | 06:18 PM
RebelDS's Avatar
Default Dang jets!!!
How was I to know, and especially the dealer, that the main jets in the Prairie are the slotted and not the hex jets. I bought the hex jet and noticed when I took the float bowl off that the main jet in the Prairie is the slotted jet. I tried the hex jet, but it stuck out too far. I got the float bowl screws off pretty easy, using a ratchet and a phillips head in a socket. But in putting the screws back in, I may have stripped the head a little. I need to go ahead and replace the Phillips head screws with allen head screws. Anyone know the size and where you can get them? Preferrably the high carbon ones that will not strip. Thanks.
Old Apr 12, 2003 | 06:35 PM
Scotia650's Avatar
Sgtrock had posted in an earlier thread that they were 4x14mm.
I searched under "carb" and found the previous discussion if your interested.
Old Apr 12, 2003 | 08:13 PM
Haynes1111's Avatar
I replaced my several months ago. The size is 4 x 8 mm. I found 4 x 7 mm at Lowe's and they have worked fine.
Old Apr 12, 2003 | 09:39 PM
RebelDS's Avatar
Haynes, I read in the archives where some tried 4x10mm or 4x12mm, but Sargent said they were a little short for him and he was going to try 4x14mm. I never saw a response to where he stated if that size was better or not. If he tried 4x10mm and they were too short and you are using 4x8mm, are these carbs a little different?
Old Apr 12, 2003 | 10:22 PM
SgtRock's Avatar
I measured the stock ones in my '02 and they are 4x14mm. I have a box of 4x14 here but I haven't put them in yet. I'll try them out tomorrow and let you guys know how they fit.
Sgt_Rock
Old Apr 13, 2003 | 12:01 AM
Haynes1111's Avatar
I called my dealer awhile back and he said they were 4 x 8 mm. I could only find 4 x 7 mm and they are working fine. I took the screws to Lowe's with me to match them up.
Old Apr 13, 2003 | 01:54 AM
RebelDS's Avatar
Mine is an 03......do you suppose the 02 uses different length screws than the 02?
Old Apr 13, 2003 | 06:41 AM
Haynes1111's Avatar
It could just be me. I can screw most things up without trying. Take the screws with you and match them up in length. I could only find ones that were slightly shorter.
Old Apr 13, 2003 | 01:32 PM
Scooter650's Avatar
Just did mine yesterday (2002 Prairie 650), my Lowes does not sell allen head bolts any longer (go figure), so I went to Home Depot. They are 4x14, but they only stock 4x12 or 4x16; I got the 4x12 and they are fine, but the 4x16 I think would be a little easier to deal with.
Dropped the 142 jet out of the back carb, went down between the back of the tranny and the motor, will fall out on the trail sometime, but now I need to go pick up a 142 jet for the front carb. The hardest part of the whole thing is the stupid little brass screws, why can't they use an allen head at the factory, make the techs and our lives a little easier. I ended up stripping out 3 of the 8 and having to use needle nose vise grips to "convince" them. Needless to say, this ruins the screw.
Did find out I was running stock jets 142r 138f for altitude of 5200'! Since I have modified the snorkle, put 3 vents in the lid of the airbox, and did the Nyroc mod on the pipe, it has been running a little lean, so hopefully this will fix it and not make it all jacked up!
ReconBayou
Oct 31, 2022 05:37 PM
blueandy88
Sep 7, 2020 03:11 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
