KFX700 Yoshimura Exhaust(good info)
Old Apr 17, 2003 | 02:08 PM
mtecate4g's Avatar
Default KFX700 Yoshimura Exhaust(good info)
I talked to yoshimura about their dual exhaust system. It has a cross over tube which causes scavenging like a single exhaust would but with better flow. The reason for this is with a single you get a scavenging effect causing better torque and low-mid power. The duals usually give better topend because of the higher flow rate. This dual system with the cross over will have single lowend torque and HP with the dual top end power. Thats awsome. Now if it isnt to expensive i am going to order it instead of the HMF. But if the price isnt real high i am going with the Yoshi. This is great news if you ask me!!
Old Apr 17, 2003 | 02:22 PM
Bruce403's Avatar
Did they say when their dual system would be ready?
Bruce403
Join ATVA - Support our Sport
2004 V Force
2002 Prarie 650
2000 Banshee
RoostItUp's Avatar
Just like the old Ford exhaust systems.
Old Apr 17, 2003 | 02:28 PM
mtecate4g's Avatar
They said it should be available in about a month. I hope sooner then that. But if it performs as good as it should it should be well worth the wait.
Old Apr 17, 2003 | 02:33 PM
NYVForce's Avatar
Great I'm putting on my HMF dual today I guess I'll sell it in a month if the yoshi is better $$$$. Darn
Old Apr 17, 2003 | 04:54 PM
Vforcer's Avatar
NYVorce .... I am betting you won't be disapointed with HMF.
I called Yoshi before I ordered the HMF. The HP they were expecting was the same as HMF was
showing on their dyno. ................ Mine gained a bunch of bottom / mid range torque with the HMF
Old Apr 17, 2003 | 06:54 PM
Force's Avatar
Pipes will be OK but clutching and CDI are the way to go and still looks stock.
Old Apr 17, 2003 | 08:37 PM
DirtHawg's Avatar
I am sitting and waiting on those Yosi Duals as well. You guys speak up if they become available. They look awsome. I hope they sound as good as they look.
FORCE: can you elaborate a little on CDI and Clutching?
Old Apr 17, 2003 | 10:29 PM
Force's Avatar
I used work partime at snowmobile dealer and they raced Artic Cats. They wound spend weeks in the field working on clutching for grass drags.When they got done you would of thought they spent $5000 on motor and all they did is make it shift at the perfect time. Ramps and weights are where its at. V-Force has very similar clutch as sled. This is what Ill being doing since I plan on racing in stock ATV drag races next winter.
Old Apr 18, 2003 | 10:21 AM
mtecate4g's Avatar
force
Your right about the clutching but i want the ultimate performance. I am going to get a tach so after i get the pipes put on i can get the shift rate and such spot on for the pipes HP curve.
