why synthetic?
Old Apr 19, 2003 | 12:22 AM
badprairie's Avatar
Default why synthetic?
what does synthetic do that normal oils dont?
Old Apr 19, 2003 | 12:38 AM
nyroc's Avatar
It doesn't thicken up when cold as much, so it flows better and prevents accelerated engine wear that occurs at startup. Doesn't get as thin when hot.
It doesn't break down at hot spots and form varnish, helping guides and bearings last longer.
Higher film strength helps keep parts from wearing as fast even when hot.
A real company did a real test on synthetic oil. They found that group of Taxis with synthetic oil changed at 10,000 miles all their life had less engine wear than another group of the same taxis (same car, same mileage, the same city) that had their oil changed at 3000 miles with conventional oil. I don't have proof of this, but heard it from a few different sources.
That is not to say that you should change synthetic less often, just that synthetic drastically reduces wear.
BTW, consumer reports tested slick 50 on some identical cars. They also used some of the same cars without slick 50. They drained the oil and drove them down the road w/o oil. They all seized in approximately the same place.
Old Apr 19, 2003 | 12:42 AM
badprairie's Avatar
thanks what should i run?
Old Apr 19, 2003 | 12:58 AM
RebelDS's Avatar
I've seriously considered running synthetic in my truck. I know it's a lot better than regular oil, but didn't know if the additional cost was worth it.
Old Apr 19, 2003 | 10:37 AM
monteSS's Avatar
If you compare costs directly it is actually cheaper to run syntetic that a good dyno oil.
Old Apr 19, 2003 | 11:25 AM
mastrblastr's Avatar
Badprairie, 0w40 or 10w40 seems to be pretty popular. Even a 10w30 would be fine.
Old Apr 19, 2003 | 12:08 PM
nyroc's Avatar
Might not be a good idea putting synth in your truck. Not that synthetic won't be good for it, but most people trade them.
I told myself I was keeping my truck forever and I did not, and I wasted my money putting synth in it.
Old Apr 19, 2003 | 10:17 PM
Lightman's Avatar
I run what I feel is the absolute best for our engines, Amsoil fully synthetic 0w-40 4-stroke Atv oil. No I'm not a dealer, after much research I've determined this is one of the best choices out there. Another good oil is the mobil 1 synth 10w-40.... Either way if you plan on keeping your quad a while, use synthetics. Your engine will last longer and remain totally clean, no sludgy buildup like the dino crap leaves![img]i/expressions/face-icon-small-happy.gif[/img]
Old Apr 21, 2003 | 12:11 AM
Chris142's Avatar
Anybody heard of Castrol Act;evo oil? The jug says that it's synthetic. It's $3.00 a qt, Alot cheaper than the Kawachem/Motul I was running @$11.00 a qt.
cornermike
Aug 10, 2016 06:47 AM
Alex G.
Sep 19, 2015 06:34 PM
Haakon
Aug 24, 2015 01:54 PM
Technical and How-To Articles
Aug 21, 2015 09:31 AM
toonces
Jul 31, 2015 09:27 AM
