dinli 90cc start problem
My sons 01 dinli was runing good then it started to loos power took spark plug out had spark then I closed the gap on the spark plug a little and bam it started ran for a little while then it again same thing now it will not start can someone help trying to get him back out there riding with me again
starting solution
Ive been messing with one of these for about a month now and have this one figured out. You would have to feather the throttle on mine to get any rpm and would die constantly. It would idle better if I plugged the inlet of the carb a little with my hand so I cleaned the carb, didn't solve a thing. I took out the reed valve and I could see a hairline of light through them, I bent them in a little to seal it and that didn't solve it. I had spark so I was set on fuel.... BAD IDEA I noticed when I turned the lights on it would stall. so as a last resort I tested the stator, and the coil, both a little on the low side of specs so I ordered from ebay a stator, high perf coil, and for fun a no limit cdi all for about 100 bucks. Installed them all at once so I cant tell you what made the difference but this thing RUNS. one last memory the spark I had was visible but the new spark is down right spookey so I hope this gets you going faster then I did.
Well since yesterday I have come up with this. I lowered the needle to the lowest setting. The quad starts right up but won't idle for any length of time. It will run though with the choke in the up position, but when I push it down it will die? The spark seems to be good I have a bright white spark. The engine is not yet broke in so I can't tell you how it runs at mid to w.o.t.. I will probable try the new coil and stator they have never been replaced. I also checked the compression and it was at 139psi, which was a big improvement over the old cylinder which was at 89psi.
to quote the man
got to quote the man. "if your quad won't idle, clean the carb/jets. if it bogs down when giving it throttle, clean the carb/jets." there is a sticky in the chinese section about carb adjustments. this is the main problem with no idle/no throttle up problems. CLEAN THE CARB/JETS..........
