Kids Quads & Other ATV's - Ask an Expert! An area where experts in their field will answer non-general questions about your Chinese made ATV. mywifesquad, LT80, LynnEdwards and other experts will answer your questions as they have time.
need help!!
Old Aug 8, 2013 | 06:00 PM
psilman's Avatar
hey i must of been mistaken or something. I tried starting it again and pulled the plug out and it is wet with gas. And i do have a fuel filter on it. could my valves still be wrong? I set them to what the service manual said.
Old Aug 8, 2013 | 06:04 PM
psilman's Avatar
even when i sprayed the start fluid in wouldnt run. So im guessing that it has to do with the spark or the valves
Old Aug 8, 2013 | 09:50 PM
psilman's Avatar
I was reading some other peoples problems on here and a similar situation like mine was caused by the cdi unit. I actually have two of these bikes and I took everthing electrical off my other one and put on this one and still same thing. I also pulled the carb off other and put on and still the same thing. The other bike runs great. That why im leaning more towards the valves or the timing. Im going to check the timing on other bike and see if it matches up.
Old Aug 18, 2013 | 01:02 PM
psilman's Avatar
well i think i finially found it! looked at the stator were it is on crank and looks like the key is bad and it not lined up right. must not be firing at the right time. need to get a puller and i think problem solved! thanks for all your help though.
