Lt 80 fuel mix?
Old Sep 3, 2003 | 08:46 PM
LT80's Avatar
LT80 Expert
Default Lt 80 fuel mix?
Yes it is lean, but I feel it's from the carb having something obstructing the fuel. It acts like it does cuz when you push the throttle hard it gulps in too much air cuz the fuel is blocked. To feather it helps, tells me alot.
Take the carb off and do a good cleaning (remove both jets),INCLUDING removing the brass where the needle sits and making sure thats all clean.
Glad to help [img]i/expressions/face-icon-small-happy.gif[/img]
Old Sep 4, 2003 | 08:00 AM
TomZilla's Avatar
Just guessing here, but does the carb on a lt80 normally flow oil/fuel through the jets? If not wouldn't it need to be jetted a little richer? Also if it is oil injected could there be an air leak at the point of injection if it is not through the carb and not blocked off?
Old Oct 24, 2019 | 07:52 AM
Chris Vickers's Avatar
Big bird
Originally Posted by 450Rutmaker
alright I have it all changed over and a mixture of 32:1 It still is smoking like crazy. I just had a new top end done. Also when you pat the gas it runs good but when you punch it or hold it at a steady speed it shuts off. Then is kinda hard to restart I havent changed the jetting why is it doing this?
The reason it does that is the bottom of your carburetor has a little tank it feels all the way up to a certain line now if you hear it for throttle it’s gonna have enough gas to drink it all but if you have your jetting see it maybe too low or too high it’s not gonna take the throttle response so the best spot for your dating is about the middle not if you check that and it’s at the middle try raising it one notch
Old Oct 25, 2019 | 08:47 AM
LT80's Avatar
LT80 Expert
Sir, it's a 16 year old thread dude. FYI: A period and a comma would really help others understand what you are saying.
ltrmc02
Aug 22, 2021 02:34 PM
SureCanUSA
Sep 14, 2015 09:57 AM
PrairieDog126
Sep 12, 2015 06:53 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Elkaholic
Sep 6, 2015 02:44 PM
