Dirt Wheels Magazine
Old 12-11-1999, 09:47 PM
TxDoc2's Avatar
Did you have any yard left after dragging that around?
  #32
Old 12-12-1999, 01:42 AM
Ryda's Avatar
Yeah really!Let's see that pic!What did you do,take a tape measure and measure everything?!How did you get how much weight u pulled around,how did u figure out the weight?YOU GOOD,mmm hmmm,i recon!
  #33
Old 12-13-1999, 01:41 AM
RoostKing's Avatar
MAX6x6,
You are too much. What EXACTLY does the Max rule at? I can name a dozen things that my LT 250 R, Let alone a 400 Scrambler, can do better than the Max, I bet you can name a dozen things your Max can do better than my LT 250R. You never answer your detractors or prove your point. After I tell you about a friend puling 3500 pounds uphill, you come back with another lame story about dragging twigs around. I actually am starting to believe that you are scared of power. If I owned a Max and was told a 4-CYLINDER car motor would fit in my Max, I would jump at the information. But I guess 25-30 MPH is fine for you. Have fun...
RoostKing...
  #34
Old 12-13-1999, 05:30 PM
BIGBEAR4x4's Avatar
Max how did u stack all that wood on one tree???????I dont think u did. but prove me wrong and post the pick.
Im not saying the max sucks cause i would love to own one but i doubt its as good as you make it out to be.
  #35
Old 12-13-1999, 06:40 PM
Max6x6's Avatar
RoostKing - Both those STVs (some terrain vehicles) you named are only for speed. They can't handle any of the real off road like my Max can.
BIGBEAR4x4 - Stacking trees on top of the cedar was really no problem. It has all those branches that hold the other trees in place. The cedar tree that I used was about 16" in diameter and 30 feet long, it must have weighed about 800 pounds just by itself. The only problem I had was that it was stacked to high that when I drove under other trees many of the would get scrapped off. I did get a pic and I think it should show the size pretty good. The Max is not as good as I make it out to be. The Max is BETTER than I make it out to be! I'll show you June '00 in KY. Be there.
MaxRules
  #36
Old 12-13-1999, 06:46 PM
benelli's Avatar
Max, No comment on the bassboat pull?
  #37
Old 12-13-1999, 07:36 PM
Max6x6's Avatar
First annual bass boat pull - Sure we can have a tug of war. Since you have an outboard, to be fair I must have an outboard of equal HP. Another way of being fair is to take off your outboard. While my wheels are paddling you can use your hands to paddle your boat, that way neither of us use an outboard.
MaxRules
  #38
Old 12-13-1999, 11:10 PM
benelli's Avatar
Max, If you want to be fair about things then why do you compare an atv with 6 wheels against one with 4? And one designed to float with one that don't?
  #39
Old 12-14-1999, 12:14 AM
Max6x6's Avatar
Finally someone admits it, there is no comparison to the Max! Just show up at the ride in KY and afterwards we can trade in your old boat for a new Max.
MaxRules
  #40
Old 12-14-1999, 11:13 AM
Bill.Ciliberti's Avatar
Never in a million years would I ever concider trading my quad for a Max.I sometimes trail ride well in excess of a 100 miles in a single day.Try doing that with a Max.If someone GAVE me a Max,perhaps than I'd own one.=======Bill
Quick Reply: Dirt Wheels Magazine
