polaris 90 carb problem. help!
Old Nov 6, 2003 | 09:16 PM
hardwood700's Avatar
Default polaris 90 carb problem. help!
My son's 90 is spitting gas out of the carb while idling. could this be that the float need adjusting? Or is it something else?
Old Nov 7, 2003 | 07:16 AM
TRexTommy51's Avatar
Adjust the float position. This is done by bending the tab that pushes up on the pin. Make sure you don't cut the fuel off. Also make sure that the machine has fuel at wide open. You can lean it out ands burn it up quick if you don't.
Old Nov 10, 2003 | 05:21 AM
moonshiner's Avatar
hi , our does as well but with the air tube on it will be repicked up and burn..I think it is due to the high secondary compresion and poor std. reeds not closing quickly / fully enough at idle. my vote is don't worry or change your float level unless you have more serious symptoms.
Old Nov 10, 2003 | 11:06 PM
thanks u guys. i will leave it where its at. its not causing a problem accept the air box gasket swelled up and the air box seems to have warped so it doesn't seal. i ordered the k&n filter and air box from advanced sleeve. i hope that will work well. i just hope i caught it soon enough.
thanks again.
njrider64
Jul 4, 2017 01:40 AM
gfl0224
Jun 27, 2015 06:52 PM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
kevbowe
Jun 1, 2015 01:17 AM
