MODIFIED STOCK PIPE
Hello.Anyone know if on the exhaust pipe on scrambler 50 or alphasport 50,can I performance making anu holes or anything???
The other exaust pipes type tonco or whr are very expensive for me and i dont like to cut the battery box.Thanks.
Sounds like no one has drilled holes into their factory muffler system. Looks like one of the pipes from the below are your limited choices...
http://www.wrhracing.com
http://www.trinityracing.com
http://www.hetrickracing.com
http://www.bncracing.com
http://www.rockymountainatv.com
- FMF Fatty pipe might work for you...
- You might be able to find something on e-bay.
Note: For best performance gain, you should also upgrade the filter and re-jet the carb at the same time. If you can't afford the expensive pipe, don't forget to save your limited pennies for these items as well. As a bundle, their combined costs add up very quickly too.
Hope this helps...
mrtidy
Feb 3, 2016 05:00 PM
greg86hd
Sep 16, 2015 12:32 AM
