Lem Cayman 50
#16
Just like brake shoe springs on old atvs and motorcycles. Easier if you have the master links off,shoes over the main hub,hook the springs while you slightly tilt the shoes inward to get slack,then pop the assembly back over the main hub.Then install the links. At least it was easier for me on the Ktm 50s this way. If you have it all together then use needle nose pliers to pull the spring end close enough to where you can pop it in with your thumb.
