Kowasaki vs eton
Reverse gear shift cam, reverse gear shaft, reverse drive gears, shift drum, shift forks, two transmission gaskets, more bearings,pins, and seals. And yes last but not least a electric shift motor that makes all this extra stuff work so you can go into reverse gear. That is what DRR is talking about.
DRR if your correct I apologize.I was told it was an "electronic" reverse.What you describe is simply an electronic "shifted" reverse.Since nobody can seem to tell me any "facts" I will stop talking about the 05s until I know my info is correct instead of repeating bad information.The 05s are supposed to be in around April sometime.[img]i/expressions/face-icon-small-blush.gif[/img][img]i/expressions/face-icon-small-disgusted.gif[/img]
