LT 80 Boost
Old Apr 8, 2004 | 10:16 PM
fasterz's Avatar
Default LT 80 Boost
What are the free mods i can do to make my lil bros lt80 a little faster, the thing is complete stock never been touched inside. i heard theirs somethin in the exhaust and carb you can take out? is this true, where at are they? what is this clutch mod you can do? how do i do it? by the way im very knowledable when it comes to quads. thanks alot
Old Apr 9, 2004 | 08:47 AM
asfasasu3's Avatar
Default LT 80 Boost
You can do a search for LT80 mods and you'll probably be surprised how much you'll find in here. The spacers are in the exhaust, take the pipe off the motor and there it is. The other is in the carb, on top of the slide, just a spacer also.
Old Apr 9, 2004 | 10:42 AM
LT80's Avatar
LT80 Expert
Default LT 80 Boost
You can remove the head gasket. That'll bump compression a lil. You can also remove 2 of the front clutch rollers.
That's about all I recommend for a stock machine.
Old Apr 9, 2004 | 10:54 AM
asfasasu3's Avatar
Default LT 80 Boost
When removing the head gasket, does it seal with out it? I've never heard of not running some sort of gasket there. Is it even worth the trouble to do it? Thanks!!!
Old Apr 9, 2004 | 11:17 AM
LT80's Avatar
LT80 Expert
Default LT 80 Boost
Yes it seals. You use a lil gasket stuff or grease and it'll be fine.
Worth it? It takes 10 minutes to find out [img]i/expressions/face-icon-small-smile.gif[/img] Some say yes, others say no. [img]i/expressions/face-icon-small-happy.gif[/img]
Old Apr 9, 2004 | 11:32 AM
SANDMAN430's Avatar
Default LT 80 Boost
never heard that trick before.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 9, 2004 | 11:56 AM
asfasasu3's Avatar
Default LT 80 Boost
Your ten minutes turns into my day and a half !!!!! lol !! Me and ole murphy are best of friends !!! I had one guy tell me there was no way it would seal. Thats why I asked.
Old Apr 9, 2004 | 12:15 PM
fasterz's Avatar
Default LT 80 Boost
where and how do i remove these 2 front clutch rollers
Old Apr 9, 2004 | 12:40 PM
asfasasu3's Avatar
Default LT 80 Boost
If your sitting on the quad, they are on the left side. I had to take the foot pegs lose from the frame, if you still have the plastic from the rear of the pegs to the rear fenders, undo it there also. Remove the side cover revelaling the front and rear clutches and drive belt. the rollers are in the front clutch. You have to remove the clutch and take the back caver off to get to them. The clutch on ours would not come off ez, so beware. It's not really a big job, took me 2 hrs to get every thing apart, and about 15 min to put it all back. Funny how it works like that!! You might want to do a search on here for more clutch info or PM LT80, he's the man on these things!!
Old Apr 9, 2004 | 12:43 PM
asfasasu3's Avatar
Default LT 80 Boost
Speaking of clutches, how often should the belt be replaced? Any measurment on it to tell how worn it is? Any good belt secrets?
