wider track on lt80
Old Dec 5, 2004 | 03:08 AM
  #61
fishslab's Avatar
Default wider track on lt80
I posted a couple of photos of my widening kit availible from most hardwar stores near you. It also includes flipping the front wheels. It is good for about 5" total in front, which for my son, has been plenty so far.
Old Dec 5, 2004 | 03:38 PM
  #62
Quad4Fun's Avatar
Hey FISH,
Does that seem strong enough?
Haven't had any problems so far?
Looks simple enough and cheap if it works......
Old Dec 5, 2004 | 05:05 PM
  #63
fishslab's Avatar
I guaranty it is stronger than the stock set up. Could you imagine bending one of the bolts through those two nuts? Ain't gonna happen. It has been on for about a year. It has held up to jumpimg and me popping wheelies on it.lol Also you get more action out of the front suspension when you move out on the ends of the front.
Old Dec 7, 2004 | 03:11 AM
  #64
Voodoo52's Avatar
Ok on my son's lt I can't figure out what the hell is wrong. When it sits there the shock on the one side seems to be compressed so I thought it was blown. So to be sure I switched the two shocks around and the other shock did it too! Mind you I installed a set of Works all the way around on the Lt. Both wheels are tipped in but one more than the other. I also have a set of stud extenders on it I believe they were made by Moose. ( I'll have to double check) So what is making the shock compress? And why are the wheels tipped in so much? Could the extenders possibly be bent? I even put on other spindles and had the same results.
How do the Kasea shocks or the new ones form Midwest compare to the Works shocks? My son races MX and I gotta get this thing wider without the wheels tipping in so much.
Old Dec 7, 2004 | 03:39 AM
  #65
fishslab's Avatar
Some things that could be wrong if you're sure it's not the shocks. Bent wheel, A arm, shock mounts, or frame.
Oct 10, 2015 10:20 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
merryman
Sep 19, 2015 03:15 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
