90cc power boost
Old Mar 27, 2005 | 01:12 AM
  #21
DANO38's Avatar
Default 90cc power boost
Has anyone attempted to relocate the carb. on the predator or similar 90's? I noticed the reed cage is at the top side of the jug, and if
you coluld fabricate a new intake and hose to relocate the carb. then there is plenty of room in the area where the injector oil reservoir is to install an airbox. Hopefully one that is waterproof enough to go through mud and water, yet still be less restrictive. Just think, it could have a cover that is accessible by removing the seat, and pops right off with no tools, so you could easily inspect and clean the air filter!
Old Mar 27, 2005 | 07:43 PM
  #22
Slydog1's Avatar
Air Box ? We run a 2 stage uni filter and an outerwear. I put the filter on top of the left fender. Yes I drilled a hole in the fender and used pvc to connect it. It works great!!!!! Hasn't even sputtered one time. Just to let you know what we go through Josh was yelling at me because he couldn't keep the mud off of his googles. You could imagine what he was like fram the googles down. Fun Fun Fun!!!!!
Old Mar 28, 2005 | 07:53 PM
  #23
Trasher's Avatar
Originally posted by: JWz400
Are those viper 90r's you'er talking about Knowpig and if so did the exhust bolt right on with out changing or moving a lot of stuff/
I'd like to know also. Please let us know what you had to remove or cut
2quiker
Mar 22, 2022 08:36 PM
byronman
Sep 6, 2015 06:34 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Logan Collins
Sep 5, 2015 08:03 PM
toonces
Sep 5, 2015 01:14 PM
