lt80 rebuild
Old Apr 6, 2005 | 03:23 AM
stevendsm95gst's Avatar
Default lt80 rebuild
time to rebuild the lt80. There are a few things i would like to do. Can anyone point me to the right direction. What should i bore it out to? Where can i buy the piston? Any tips?
Old Apr 6, 2005 | 11:33 AM
asfasasu3's Avatar
I would bore it only as much as needed. You need to mic the bore now and see how big it is. Then buy the next bigger piston and have the cyclinder bored to fit the piston. Then before you start putting it all together, slide the rings into the cyclinder and check the end gap. (make sure it is at the specs that is given with the piston information)
Boring these little things really doesn't provide a noticable power gain, so bore as little as you can to save for the next time.
Pistons can be had from almost any parts supplier. Alot of builders perfer the stock Suzuki pistons. (I don't know who makes them for Suzuki) As for myself, I kinda liked the Pro X piston. I don't know if its any better or worse than Weisco or others, but it did look really good and it had coated skirts.
As for tips? Doing a search on here will provide more info than you'll ever need. The rebuild is pretty stright forward. If you need more, I will try to help, or ther are others on here that can help.
GOOD LUCK!!!
Old Apr 6, 2005 | 01:38 PM
thanks im pretty sure thats all i needed to know. Im going to see if i can get a cp piston for it.
Old Apr 6, 2005 | 09:44 PM
hateful's Avatar
stick with suzuki or prox piston for it they hold up the best.
Beeline08
Nov 11, 2016 04:00 PM
QuadRiders
Oct 22, 2015 04:13 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
merryman
Sep 19, 2015 03:15 AM
