OIL INJECTION QUESTION?
Old Apr 17, 2005 | 08:51 PM
JkAss's Avatar
Default OIL INJECTION QUESTION?
On the Suzuki LT 80 they put a washer with a .25" hole at the exhaust port going into the pipe. They also had a spacer inside the carb to keep the slide from going for full open. With those 2 things removed there was huge difference. Plus we put a pipe and rejetted the carb. That thing hauled A*#.
Old Apr 17, 2005 | 09:12 PM
Raptorlegs's Avatar
T Rex Rider
What irritates me is!
Those 6-packs work pretty good.
Defcon, if anything it probably has a restriction in the cdi.
ps - wrh16 knows more about these minis than anybody I've ever met. Ask while your can! [img]i/expressions/face-icon-small-wink.gif[/img]
Old Apr 17, 2005 | 09:23 PM
defcon5's Avatar
So whr16 do you know if it has any restrictor on the cdi!
So are you only here for a while!
Thanks
Roman
Old Apr 17, 2005 | 09:29 PM
JkAss's Avatar
Send wrh 16 a PM.
Old Apr 17, 2005 | 09:31 PM
  #15
defcon5's Avatar
Don't want to bother the guy, he'll see the post just as fast as he'll will see a pm.
Old Apr 18, 2005 | 09:10 AM
  #16
wrh16's Avatar
I would like to get one of the Unison's to work with/have and build into a racer but the funds won't allow it this month.
Generally speaking. The restrictors in the exhaust are limited to the Pw's, JR's, and little lt-50's.
The cdi limiter is probably not there, generally the less than huge companies tend to limit speed by either sprocket size, carb sleeve restricters, or variator spacers.
Also some exhaust I have seen as of late have an additional baffling pipe that is removable by bolt/screw removale.
Will I be here often? Hope so! As long as I can log on automatically.
I have been extremely busy as of late, which limits any available time for e-mail or forum response. When I do get to sit down in front of a computer that is generally due to exhaustion. Hence making it difficult to respond completely.
Just think, I was working at Garland Suzuki in Dallas, Texas Metro area before they ever had a 4 stroke, and well before the first LT-80's were released.
I must have assembled a hundred of them, I may well be one of the few guys still doing this that had the pleasure of uncrating, assembling, and doing the pre delivery On the LT-250/500's. I was always quite thrilled to service out a Quadzilla 500.
Old Apr 18, 2005 | 11:30 AM
  #17
defcon5's Avatar
Were lucky to have a man of your stature in our forum, our door is always open so pop in when ever you feel the need.
Thanks for all the help.
Roman
EIF
Apr 20, 2017 07:15 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
