UNISON DESERT CAT 90 UPDATE!!!
Old May 16, 2005 | 02:49 PM
defcon5's Avatar
Default UNISON DESERT CAT 90 UPDATE!!!
I HAVE YET TO CHANGE THE GEAR OIL. I SUPPOSE I SHOULD.
ROMAN
Old May 20, 2005 | 01:17 PM
HPIA4v2's Avatar
Defcon5,
got my DC90 last Wednesday with the reverse gear kit.
I haven't got the time to install it though, been busy at work.
I was hoping Nick or Raceway might send me a few pictures of how the lever (which seems to be mounted on the right hand side) is installed.
Though, I am sure my wife can figure it out, heck she is a mechanical engineer[img]i/expressions/face-icon-small-happy.gif[/img]
By the way, I just wonder compare to my son Eton mini 50 the DC 90 seems to under-steer on power.
Which scare me a little. Wonder if the front suspension is too stiff or the front should have more negative camber?
The built quality is top notch, start easier than the eton (no need for choke, well there is none).
That's my first impression so far.
I'll promise will write more once I installed the reverse gear.
DJ
Old May 20, 2005 | 01:23 PM
Raptorlegs's Avatar
T Rex Rider
What irritates me is!
Those 6-packs work pretty good.
"Understeer" can be fixed by toeing in slightly but is usually more stable at higher speeds. If the camber is off, the front shockd should be adjustable. They will also losen up a little with use.
Axl_Z
Mar 9, 2025 11:14 PM
Jazperman
Aug 7, 2016 08:12 PM
chewy78
Sep 8, 2015 10:37 AM
Sep 2, 2015 11:15 PM
