k&n filter for kazuma
Welcome to the forum hadaveha, On my wifes yamoto I used the stock rubber hose and a piece of aluminun tube to mount a UNI pod filter, but you could just as easilly mount it directly to the carb. or use a piece of pvc pipe. You want to measure the diameter of the carb to fit a filter to it.
You can go to the K&N website and they have all the specs and meausrements for every possible configuration. Then go to Autozone with the manufacturers number and they will be able to order it for you.
Good luck!!!
Good luck!!!
Improving airflow leans your air/fuel mixture which produces more heat in the cylinder. Remember that fuel also acts as a cooling agent. The air'fuel mixture is far more critical in a 2 stroke than a 4 stroke. Anytime you do mods you will want to check the mixture all the way through the powerband. This will help mitigate many potential probs down the line (fouled plugs, poor power, hard starting, excessive fuel consumption and siezed pistons etc).
Anymore questions just ask!!
Like submkr said it is more critical on 2 strokes. Most 4 strokes come rich from the factory and I have never heard of a 4 stroke burning a piston from just a K&N. I highly recommend the clamp on filter on all of these chinese atv's. It is well worth it.
Jetting depends on a LOT of factors such as elevation and temperature and is much more sensative on small engines, especially when they are air-cooled. Another factor when modifying an engine is how restrictive is the stock box and will it be removed completely? Some engines won't even start with the stock jetting when the box is removed. Another factor is how restrictive is the pipe? Unplugging one end and not the other can be a waste of time and money.
What would be the point in changing filters and not changing jetting? Unless you are rich from the factory, which is not a guarantee, you would not see any noticable performance gains. Jetting is a pain but its a necessary evil when you start modifying your machine. Skipping the process can be detrimental to the life of you engine.
