AC90 2 stroke problems
Old Jan 29, 2006 | 09:55 PM
Cmymud's Avatar
Default AC90 2 stroke problems
I can't get the thing to run once it gets hot. If cold it runs GREAT. Once she gets hot it cuts off. And will not fire back up?
Just trying to figure this out. Any help would be great.
Old Jan 29, 2006 | 10:10 PM
newnick's Avatar
Sounds electical. Try searching for " coil" or "stator" using the search option. You might find some help there, and I'm sure someone is gonna give you a answer to this thread also.
Old Jan 30, 2006 | 11:23 AM
Raptorlegs's Avatar
T Rex Rider
What irritates me is!
Those 6-packs work pretty good.
You've checked the fire or will it just crank but not start?
Old Jan 30, 2006 | 11:48 AM
Fastestdad's Avatar
What legs said. If it has spark does it load up or foul the plug, does it run worse for like 5 mins till it wont run anymore or does it just die immediately? The electric choke turns off after a few mins of running so try unplugging it which will keep it on all the time and see if it will stay running. The choke works by staying on till the current running thru a small conductive wax pod that when electrical current flows thru it melts the wax and opens the choke. Bike turns off for a while the wax hardens and is conductive again turning on the choke again. (crappy system IMO.) Let us know how it goes. Fastestdad
Old Jan 30, 2006 | 12:56 PM
Cmymud's Avatar
Runs Great!!!! for about a half hour and then just dies.
I have not check to see if it has fire after it dies? I will.
And yes the plug was getting fould out so I would try a new one.
kelleycully
Sep 15, 2016 02:57 AM
SDR-II
Sep 29, 2015 01:06 AM
NatePerz
Jul 27, 2015 03:27 AM
ghost3
Jul 19, 2015 08:46 PM
