kazuma 150 oil change?
Old Feb 10, 2006 | 02:24 AM
douchie's Avatar
Default kazuma 150 oil change?
I hear your supposed to change the shipping oil in these quads(just got mine) what kind and grade of oil do i use. info greatly appreciated[img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 10, 2006 | 09:49 AM
ddrumman2004's Avatar
Seeing you live up in Washington....I would go with a good synthetic. I was using Shell Rotella T 15w-40 in my son's TRX90 but switched it to Amsoil 0w-40 synthetic that is formulated for atv's and snowmobiles. It's JASO MA rated for wet clutch applications and being it's synthetic, it has a higher flash point than regular oil and a lower pour point...down to -65 degrees. The higher flash point means it won't burn as quick as "dino" oil. Synthetics are also more shear stable....something that is needed in a shared sump engine.
It's expensive...9 bucks a quart but oil is the life blood of your atv.
If you want to buy locally at walmart...Shell Rotella T synthetic in 5w-40 would be a great choice or the regular Shell Rotella oil.
For the record, my girlfriend's 04 Bruin was burning oil on start-up due to worn valve guide/seals. I am happy to report that the Amsoil stopped that from happening.
Just make sure that whatever oil you buy does not have "Energy Conserving" stamped in the circle on back of the container.
Old Feb 10, 2006 | 10:57 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
The 150 will be fine with just about any ones 10-30 or 10-40. I use 10w-30 valvoline in my wifes yamoto 150. The 150 uses a cvt and so it doesnt have a wet clutch inside of it. And yes you definitely want to change the oil before even starting it up. I would wait until you get a few hours on the quad before switching to synthetics if thats what you wanted to use.
Old Feb 10, 2006 | 06:42 PM
douchie's Avatar
thanks for the info you guys...glad to hear you saved the bruin.
Old Feb 11, 2006 | 12:56 AM
Thank you Douchie! Good luck with the atv.
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Sw00p
Sep 24, 2015 02:50 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
