kazuma 90
Old Feb 11, 2006 | 11:26 PM
10000's Avatar
Default kazuma 90
why does the battery keep going bad?
Old Feb 11, 2006 | 11:49 PM
2manytoys's Avatar
Default kazuma 90
The factory batteries in them are junk and if you have an alarm on the atv it is defective. You can disconnect the alarm and get a new battery at walmart. Did you change the oil in it?
Old Feb 12, 2006 | 05:20 PM
10000's Avatar
Default kazuma 90
yes i have changed the oil. how can i disconnect the alarm?
Old Feb 12, 2006 | 05:24 PM
2manytoys's Avatar
Default kazuma 90
Not sure but guys here have done it or you can call and talk to John at Raceway. He recommends doing this also.
Old Mar 15, 2006 | 07:58 AM
looneytunsman's Avatar
Default kazuma 90
Your best bet is to replace the factory battery and install a on/off switch inline with the red wire going to the battery that has the fuse on it. You will then be able to elimanate any draw and keep your alarm system intacked.
Timdaddyo4
Ask the Editor
Apr 27, 2024 06:50 AM
strokesb16b
2) Chassis problems..
Sep 15, 2015 09:19 PM
rjacree
1) Engine problems..
Aug 3, 2015 10:21 AM
michdagh
Sep 19, 2002 05:32 AM
