NEED HELP!! new sunL 90--won't start/no brakes
SOMEBODY HELP.......QUICK!!! I just put together a new sunL 90 for my son's 6th birthday--TODAY!! It won't start and the brakes don't work. ANY SUGGESTIONS?????? THANKS SO MUCH FOR ANY HELP YOU MAY OFFER. Purchased from Raceway ATV but doesn't look like they have cust. support on weekends. That stinks!!! [img]i/expressions/face-icon-small-blush.gif[/img](
need a little more information, when you try to start it what's it do?, you know the brakes need to be on before starting or else it won't start. it's a safety item on all the automatics. on the brakes issure, does the lever just go in? if thats the case it probably just needs to be bleed. if you don't know how do it let us know. also make sure the choke is pulled out when starting for the first time, i like to put the rear of the quad on a block to get the rear wheels off the ground before starting that way you can rev the engine up a little without worring about it moving also let it run for 15-20 minutes before riding it,
Raceway ATV....THANKS so much for the offer of support. I truly appreciate your help. We managed to get it running and the brakes just needed to be bled. You truly are as good as they say on here!!!! My son LOOOVVVEEEEDDD it. [img]i/expressions/face-icon-small-blush.gif[/img]) I am definitely happy with the purchase.
oliveiracarlos
09-07-2015 03:39 AM
