won't start
Old Mar 26, 2006 | 12:24 PM
socaltoyman's Avatar
Default won't start
Is the starter turning the motor over or is just the starter turning over? I guess this is the confusion???
Old Mar 26, 2006 | 08:41 PM
steigs's Avatar
Default won't start
Thanks for the info. I will definatly try it when I get time. I work 60-70 hrs a week as a welder/millwright
Old Mar 26, 2006 | 09:01 PM
steigs's Avatar
Default won't start
the starter motor is spinning,the chain is on, the engine wont turn, something is not engaging. I need to try the things that were suggested and I will reply with good news I hope!?
THANKS FOR ALL THE INFO THESE ARE ALL GREAT SUGGESTIONS.
Old Mar 27, 2006 | 12:21 AM
SkipCarter's Avatar
Default won't start
I think there was a confusion of terms. I took "not turning over" to be cranking, but not firing. In this case, I'd look at the kill circuit, and the left handlebar control kill switch in particular (see my previous post).
If starter turns, and engine does not crank, then there's something broke inside the motor. There is a woodruff key (shear pin) on the flywheel. With the case open, and if it looks the its just spinnng there, then this could be the cause.
You will need a Honda flywheel puller to get this off and a shop manual for advice on disassembly and assembly.
Old Mar 27, 2006 | 10:24 AM
  #15
billl2099's Avatar
Default won't start
steigs
pm me your e-mail address and i'll send you a manual for your engine if you don't have one already.
bill
Old Mar 27, 2006 | 10:14 PM
  #16
steigs's Avatar
Default won't start
Thanks I sent my email this will be very helpful
Old Mar 30, 2006 | 05:53 PM
  #17
billl2099's Avatar
Default won't start
what size redcat is it? did you received the engine manual i e-mailed you?
Old Mar 31, 2006 | 07:42 PM
  #18
CalOffRoad's Avatar
Default won't start
Bill2099,
Do you by chance have a manual for a 2005 Kazuma 250? I have the utility model but I think the drivetrain is the same as the sport ones. I have been trying to find a manual for this machine & I need to do some work on it soon. I have been reading the posts which you and others have put out some good & much needed info. on these ATV's. I am having the common problem of the motor not wanting to idle & was hoping a manual will help me before I resort to changing out the carb.
Thanks much.
Chris
Old Mar 31, 2006 | 09:52 PM
  #19
steigs's Avatar
Default won't start
Hi, I'm back from another long week! It is a 50cc. I did recieve your email w/the manual, THANKS! this will help alot. Hopefully tomorrow I will be able to fix it. I have not been home lately to try the suggestions given.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
