predator 50 won`t start
Old Apr 6, 2006 | 09:43 PM
lsittingbull's Avatar
Default predator 50 won`t start
I just got this little predator 50 today, I changed spark plug, changed gas in tank and carb bowl. Battrie has a good charge. When i pulled out the spark plug and connected it back into the boot and tried to start it to check for fire(had good voltage arc ). one thing i noticed was voltage would arc from the rubber boot to the front tire?. if anybody can give some suggestions, i willing to learn.
Old Apr 8, 2006 | 10:07 AM
Blazer25's Avatar
Hello, I am fairly new to the mini quad. I don't have an answer to your question, but I do get a lot of great suggestions from a different forum at www.predatorowners.com It is a website designed specifically for predator owners. Good luck!
Old Apr 8, 2006 | 10:47 AM
pemad's Avatar
Try replacing the plug boot. They are cheap and may do the trick. Just unscrew the one on it and screw the new one in. You can get the NGK boots for around 5.00.
Cheers!
cbcole02
Sep 7, 2015 06:16 AM
Berjr
Jun 15, 2015 04:41 PM
Predator_500
Jun 13, 2015 03:01 PM
1000gade
May 27, 2015 12:37 PM
Falcon150
May 25, 2015 05:36 AM
