lt 80 coil assy?
Old Apr 9, 2006 | 01:58 AM
NORCAL68's Avatar
Default lt 80 coil assy?
i have to ask if there is any way to check the coil assy before buying a new one? doesnt seem to be getting spark turning over real good . took spark plug out dry as could be. checked spark on frame and no spark. could any one help? thanks for your time
Old Apr 9, 2006 | 11:37 AM
LT80's Avatar
LT80 Expert
You check them with an ohm meter. Your local zuki shop can tell you the correct readings. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 9, 2006 | 01:09 PM
NORCAL68's Avatar
thank you lt80!
Old Apr 11, 2006 | 01:23 AM
Irunwire's Avatar
Check your grounding wires also. If the frame is not grounded to the battery than you get no spark. Hope this helps.
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 31, 2022 05:37 PM
Joe454
Nov 20, 2020 01:19 PM
kbazzy
Sep 26, 2015 11:26 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
