Falcon 250 fuse blows
Old Apr 13, 2006 | 10:50 PM
cowgirl's Avatar
Default Falcon 250 fuse blows
Anybody have an idea what could cause this problem? Seems to go good for awhile and just blows. Thank you.
Old Apr 13, 2006 | 11:11 PM
smb05's Avatar
cowgirl,
You probably have a short to ground. Check to make sure that all your wire connections are seated properly. Check all ground wires to make sure they are secure. Look for any bare wires grounding out. Also if you have done any electrical work double check it. You may have inadvertently hooked something up wrong. Case in point my daughter helped me to apply dielectric grease on all her wire connections on her quad, I got side tracked and did not watch her put one of the connections back together. She plugged the brake cable into one of the headlight connections. She takes the quad out for a ride, pulls the brake, brake light is supposed to light up but doesn't, she blows the fuse; quad dies. This was a lot of fun to trace down but we did it together and solved the problem.
Good Luck.
SB.
Old Apr 14, 2006 | 12:42 AM
IdahoVinnie's Avatar
What he said ^^^.
Also, there is the possibility that you may be drawing too many amps in that circuit for the fuze.
Old Apr 14, 2006 | 10:35 AM
SEADAWG's Avatar
Cowgirl,
We are having problems with our Kazuma / Redcat 250. Mine is carb related, you seems to be electrical from you past postings. If you had it to do over again, would you buy it? SEADAWG
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
franklyme
Oct 21, 2016 07:18 PM
Lucas Bohanan
Sep 29, 2015 01:16 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
