Eton Yukon yxl150 wont start
Old 04-14-2006 | 03:01 PM
DQ's Avatar
DQ
Default Eton Yukon yxl150 wont start
I have an eton yukon and just can't find the problem. It was running my daughter rode it and then it just wouldn't start. I checked the spark plug to see if there was a spark and there was not, so I tested to see the resistance across the coil and it was normal. I then tested power coming into the coil and I have 7 volts on the hot terminal I then traced it back to the CDI the hot wire coming in has 12 volts and the the blue and white wire going to the coil has 7 volts. The starter turn without any problems and the battery has an excellant charge. Also when the kill switch is off on the handlebar it is quiet but when I switch the kill switch into the on position I hear this clicking noise that I can't identify. Any ideas? thanks so much in advance
Old 04-14-2006 | 09:08 PM
kawieman700's Avatar
Might want to try a ign. switch i've replaced a few in the 50 thru 90cc quads
Old 08-08-2006 | 05:50 PM
LaPurr's Avatar
I dont want to post the obvious things, but most E-tons that wont start are brought into the shop, with a REALLY simple fix. Put it in Nuetral, and set the parking brake, and try again.
Old 08-24-2006 | 12:11 AM
valki's Avatar
Dont know name but there is a main group of wires that run under the air filter box to the rear of unit. This has come loose on ours several times before we smarted up and put a lock washer on it.
jag6510
06-15-2015 06:59 PM
brinkkl2000
06-11-2015 01:46 PM
Fnqrider
05-31-2015 09:29 AM
1000gade
05-27-2015 01:37 PM
hot_shoe_cv
10-13-1999 03:16 PM
