Wrong spark plug?
Old Jun 19, 2006 | 01:22 PM
watzupdog's Avatar
Default Wrong spark plug?
Man enough.... LOL... I'm going riding in about an hr.... More than you can say.
Old Jun 20, 2006 | 01:23 PM
MoparRob's Avatar
If the plug was a 1/4" to long. Theres a good chance it would hit the top of the piston. I doubt the plug is the problem. The plug will not make the quad run hot. To lean of a fuel mixture will make it run hot, surge and be hard to start. Have you removed the plug and examined it. You should be able to tell how the motor is running. You may want to remove and clean the carb. While you have it open. Make note of the numbers on the main jet, pilot jet. If the needle is adjustable make note of which notch the clip holding it is in. This will give you a baseline on how the carb is setup if changes are needed. A air leak around the carb could also make the quad hard to start and make it run lean and hot.
Bob Maurice
1) Engine problems..
Jul 14, 2015 09:05 AM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Unzzy66
Jul 11, 2015 10:01 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
D-Hagz
Jul 4, 2015 02:19 AM
