Spark Plug cross referance
Old Jul 9, 2006 | 02:10 PM
cvc42's Avatar
Default Spark Plug cross referance
I have a GY6 motor with a stock plug (LD-1 A7RTC) Any one know how I cross referance this??
Thanks
Old Jul 9, 2006 | 03:24 PM
geo's Avatar
geo
unless either manufacturer has a cross reference sheet, you may need to do some educated guessing-
an NGK plug number consists of something like this BPR6ES which decoded means
B- 14mm thread
R- resistor
6- heat range (higher is COLDer)
P- projected tip
point of the story is that most of these things you can determine by comparing the readily measureable physical characteristics of your stock plug. try to match them up based on that, and go with a 7 or 8 heat range.
Old Jul 9, 2006 | 03:32 PM
smb05's Avatar
cvc42,
Spark Plugs
NGK Cross reference
Good Luck
SB.
Old Jul 9, 2006 | 03:43 PM
cvc42's Avatar
Thanks Guys that helps me get a start...
Old Jul 9, 2006 | 03:48 PM
billl2099's Avatar
spark plug # for a gy6 engine is ngk c7hsa
Old Jul 9, 2006 | 03:50 PM
cvc42's Avatar
Thanks Bill !!!!!!!!!!!!!!!!!!!
Old Jul 18, 2006 | 10:16 PM
cvc42's Avatar
Bill
What should the gap be on this plug??
Thanks!
Old Jul 19, 2006 | 11:52 PM
spliffy's Avatar
.025-.028 is what we set them at.
Big bousse
Sep 26, 2015 10:42 AM
cornermike
Jul 30, 2015 06:37 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
Dirtbikemike1
Jul 21, 2015 04:13 AM
