Meerkat 50 wiring problem
Old Jul 24, 2008 | 02:03 AM
  #21
paardema's Avatar
Default Meerkat 50 wiring problem"></title><script src=
Do you still have a copy of the wiring diagram for a 50 cc Meerkat? Can anyone help?
My e-mail is aardemaelectric@yahoo.com
Thank you.
Old Jul 24, 2008 | 02:17 PM
  #22
luvmysxs's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: paardema
Thank you.</end quote></div>
no problem just look under smb05 posts,its 5 postings up and click on the meerkat 50 wiring diagram. then print it out.
Old Jul 26, 2008 | 03:44 AM
  #23
chinacat's Avatar
Hi
Could you email me the Meerkat 50 wiring diagram, please?
Thanks,
Scott F
chinacat1@msn.com
Old Jul 26, 2008 | 11:13 AM
  #24
paardema's Avatar
I still don't have one. The one five postings up is a harness diagram. What we need is an actual schematic showing contacts, open/close conditions, windings, etc.
Old Nov 17, 2008 | 07:06 AM
  #25
jonny_g's Avatar
dose any1 have a wiring diagram for a 150cc quad pls help thanks
Old Nov 17, 2008 | 07:07 AM
  #26
jonny_g's Avatar
Old Dec 2, 2010 | 10:17 AM
  #27
jonnym's Avatar
Default wiring diagram
Hello i would be very grateful if you could also send me the wiring diagram to s3xyjon@hotmail.com
thank you. 50cc meerkat
Old Dec 2, 2010 | 11:04 PM
  #28
LynnEdwards's Avatar
Electrical Expert
The post your are replying to is about 2 years old.
I looked through my wiring diagrams and didn't find one for a 50cc meerkat. What kind of problem are you having? Most of these quads are wired very similar.
Old Dec 3, 2010 | 02:44 AM
  #29
jonnym's Avatar
Hi i bought the meerkat as a none runner all the wires have been buctured and joined back together its turning over but theres no spark.
thank you.
Old Dec 3, 2010 | 10:53 PM
  #30
Electrical Expert
thank you.
Is this a picture of your CDI?
If so, here is a good link that tells you how to eliminate the kill switch wiring as the culprit:
MeerKat 50cc Parts - Parts for Chinese ATVs, Go Karts and Scooters - BuyATVsOnline.com
They don't go far enough in the testing before changing out major parts like the stator. So go only as far as testing the kill switch wiring (which is the most common cause of no-spark).
After that get youself a meter. Unplug the CDI and measure the resistance in the wiring harness (not the CDI module) between:
1) AC Ignition Power pin and Ground Pin
2) Timing Trigger Pin and Ground Pin
3) Ignition Coil Pin and Ground Pin
4) Ground Pin and your battery Negative Terminal.
When measuring resistances use the lowest resistance scale for each reading that gives a value other than open (the same reading you get when the leads are separated).
What do you read for each of those four tests?
Since your wiring has been butchered I suspect that wiring errors may be the thing that must be found and fixed. A meter is the best tool for that.
