Meerkat 50 wiring problem
#32
Is there any way to get a copy of that diagram? I have one that someone has jacke all the connections on and I am trying to get it together the right way. Thanks Jeff
poolmanj@yahoo.com
poolmanj@yahoo.com
#33
poolmanj@yahoo.com
poolmanj@yahoo.com
So what do you mean when you say:
...someone has jacke all the connections on...
But I would be a little concerned about a quad with unknown history that has never run before your own eyes. It could be an unsalvagable piece of junk and not worth spending money on. I would get the engine cranking with the starter motor first (by jumping the solenoid with a screwdriver, and using jumper cables to you car battery if necessary), then look at the compression before spending any significant cash.
#35
"Earlier in the thread" is the operative phrase since that post was in 2007
The Raceway post would have been the most promising but to the best of my knowledge they are no longer posting anything at all in any forum. The other post about a wiring diagram turns out to be just a drawing of the wiring diagrams showing bundles and connectors and not how they are wired up.
Hence you may be in for a tough time getting a wiring diagram. In anticipation of your lack of success in getting a wiring diagram I was simply trying to help
.The Raceway post would have been the most promising but to the best of my knowledge they are no longer posting anything at all in any forum. The other post about a wiring diagram turns out to be just a drawing of the wiring diagrams showing bundles and connectors and not how they are wired up.
